77 cyclone question
77 cyclone question
Today i went to start my cyclone and it fired right up an i heard a quiet squel than it stoped when it was warmed up and idleing then it happens when I hit the throttel it sounds like it is coming from the right side when on seat.
any ideas of whats going on or if i shold do any thing about it would be great
Evan
Evan
77 cyclone question
I am not sure.. fan belt? Something in the chain case?
Sleds I own
1974 John Deere JDX8. (SOLD)
1975 John Deere JDX4. (SOLD)
1977 John Deere Liquifire 440. (SOLD)
1978 John Deere Cyclone 340. (SOLD)
1980 John Deere Liquifire. (SOLD)
1983 John Deere Liquifire.
77 cyclone question
you should pull the recoil and the little cover above it and chrck the fan belt. I melted a piston on my x8 last season do to a bad belt.
77 cyclone question
I just nuked my 440 whirlwind because of it. I herd the noise and disregarded it. Long story I short melted my PTO side piston, not fun at 1:30 am. I would recommend checking things out before something happens.
Scott
Scott
77 cyclone question
Could be the fan bearings also. Pull the belt and spin the fan with you finger. If it is rough or noisy replace both bearings and put a new belt on.
77 cyclone question
Thank's for the ideas i went and statred it up today and i did not here the squek but i did take off the recoil starter and the fan cover and looked at the belt and the fan they look good. it gave me a opertunity to clean out some dirt and i learned about the belt i always wonderd how that fan worked now i know i will keep an eye on it. Thank's
Evan
Evan
77 cyclone question
Im judging by the look of the leaking carb boot to the engine and the rusty exhuast that this engine has not run for quit a while,pull that sucker and go through it and replace crank seals and that carb boot at the very least.Do this now before you melt a piston or worse!
77 cyclone question
Thanks for the tip about the carb boot i will check on that tomarow This spring i will restore it and look every thing over. I just got it in December From a Neighbor for $100 it was outside under a cemi trailer for 5 years. i got it to run for the winter and have put a few miles on it and a little money into it. Here are some pictures. I will defenetly look it over and replace a few things be for i ride it much more this winter.
Evan
here are some more pictures of the progress.
http://s187.photobucket.com/albums/x117/evangun/?action=view¤t=HPIM0980.jpg
Evan
77 cyclone question
get those crank seals done asap!!!I bet when you take the old ones out there will be pieces missing from at least one of them.Last winter I got a 340trailfire for free it had not run for many years I got it to run and took it around the yard once and it seemed to run great.I then replaced the seals as I always do and almost half the seal was gone!! and it still ran!!!If I had taken the sled for a run accross the field it would have burnt a piston for sure.
Like I said replace them asap,they are a VERY important part of a 2 cycle engine.
77 cyclone question
Also look into rotating your pull start counter clockwise one position. Looks to me its installed incorrectly.
77 cyclone question
You are right about the recoil starter i thought some thing was odd with it i will move it.
about the oil seals i am new with the john deers can anyone recemend a good place to
order some and how hard are they to replace any tips will help. I have worked on simular prodjects i rebilt a yamaha exell 340 and replaced seals when engine was apart and replaced seals on a mx 80 yamaha dirt bike. Here are some videos of the john deere and my other podjects.
http://www.youtube.com/crazzygunner
Evan
Evan
77 cyclone question
If you have done seals in a yamaha then you can do this engine,just get a service manual andfollow the directions.Winderosa should have your gasket set.
