77 cyclone question
cyclone77
77 cyclone question
Post by cyclone77 »
Today i went to start my cyclone and it fired right up an i heard a quiet squel than it stoped when it was warmed up and idleing then it happens when I hit the throttel it sounds like it is coming from the right side when on seat.
any ideas of whats going on or if i shold do any thing about it would be great
Evan
b00stinGTP
77 cyclone question
Post by b00stinGTP »
I am not sure.. fan belt? Something in the chain case?
Sleds I own
1974 John Deere JDX8. (SOLD)
1975 John Deere JDX4. (SOLD)
1983 John Deere Liquifire.
JDFanPa
77 cyclone question
Post by JDFanPa »
you should pull the recoil and the little cover above it and chrck the fan belt. I melted a piston on my x8 last season do to a bad belt.
S_Kyle
Real Name: Scott Kyle
77 cyclone question
Post by S_Kyle »
I just nuked my 440 whirlwind because of it. I herd the noise and disregarded it. Long story I short melted my PTO side piston, not fun at 1:30 am. I would recommend checking things out before something happens.
Scott
77 cyclone question
Could be the fan bearings also. Pull the belt and spin the fan with you finger. If it is rough or noisy replace both bearings and put a new belt on.
cyclone77
77 cyclone question
Post by cyclone77 »
Thank's for the ideas i went and statred it up today and i did not here the squek but i did take off the recoil starter and the fan cover and looked at the belt and the fan they look good. it gave me a opertunity to clean out some dirt and i learned about the belt i always wonderd how that fan worked now i know i will keep an eye on it. Thank's
Evan
big danno 1970
77 cyclone question
Post by big danno 1970 »
Im judging by the look of the leaking carb boot to the engine and the rusty exhuast that this engine has not run for quit a while,pull that sucker and go through it and replace crank seals and that carb boot at the very least.Do this now before you melt a piston or worse!
cyclone77
77 cyclone question
Post by cyclone77 »
Thanks for the tip about the carb boot i will check on that tomarow This spring i will restore it and look every thing over. I just got it in December From a Neighbor for $100 it was outside under a cemi trailer for 5 years. i got it to run for the winter and have put a few miles on it and a little money into it. Here are some pictures. I will defenetly look it over and replace a few things be for i ride it much more this winter.
Evan
here are some more pictures of the progress.
http://s187.photobucket.com/albums/x117/evangun/?action=view&current=HPIM0980.jpg
big danno 1970
77 cyclone question
get those crank seals done asap!!!I bet when you take the old ones out there will be pieces missing from at least one of them.Last winter I got a 340trailfire for free it had not run for many years I got it to run and took it around the yard once and it seemed to run great.I then replaced the seals as I always do and almost half the seal was gone!! and it still ran!!!If I had taken the sled for a run accross the field it would have burnt a piston for sure.
Like I said replace them asap,they are a VERY important part of a 2 cycle engine.
427cobra
Real Name: Eric
77 cyclone question
Post by 427cobra »
Also look into rotating your pull start counter clockwise one position. Looks to me its installed incorrectly.
cyclone77
77 cyclone question
Post by cyclone77 »
You are right about the recoil starter i thought some thing was odd with it i will move it.
about the oil seals i am new with the john deers can anyone recemend a good place to
order some and how hard are they to replace any tips will help. I have worked on simular prodjects i rebilt a yamaha exell 340 and replaced seals when engine was apart and replaced seals on a mx 80 yamaha dirt bike. Here are some videos of the john deere and my other podjects.
http://www.youtube.com/crazzygunner
Evan
big danno 1970
77 cyclone question
If you have done seals in a yamaha then you can do this engine,just get a service manual andfollow the directions.Winderosa should have your gasket set.
