points to cdi
big danno 1970
points to cdi
Post by big danno 1970 »
Anyone ever try to put a kawasaki cdi on a 340/5? I wonder if this could be done useing the whole system I.E. stator plate cd box and coils probably need the fly wheel as well.Just wondering.
points to cdi
Wouldn't it be easier using one from a 340/22??
points to cdi
Yeah, what Kenny said!
You need everything, including the flywheel.
big danno 1970
points to cdi
Yes it would be easier to use one from a /22 but I was thinking that parts like the timing ring are getting hard to find and we all know they are getting pretty old and are starting to become unreliable.
All I was thinking is maybe we could get some of these old sleds going again with some "newer" tech parts that are available and more reliable and the fact that I personally hate points on a sled engine so I was trying to eliminate them.
Anyways it was just a thought.
Dan
points to cdi
I believe that if you stay Kioritz you'll have a better chance that the tapper length on the crank will be correct for the flywheel? Where as using anybody else's might not be. The other point that has NEVER been addressed when ever this came up when the discussion was brought up about going the other way ( CDI to Points ) was is the flywheel key in the same position on both engine cranks??? If not, this would get real extensive fast.. I am going to install CDI on a Kioritz 340 RS Free Air Engine I have, but If I find a crank that will work I will also be installing it at the same time, I will know more when I start this project..
points to cdi
Campbell has coverted CDI engines to points ( to gain reliability ) :lol22:
Cabindweller
Real Name: Jerry Zebro
points to cdi
Post by Cabindweller »
I am interested in this post myself. Been wondering if I could build a 340/5 with CDI and Duel carbs as a temporary motor for my 295/S.
