Suspension removal?
79 Spitfire
Suspension removal?
I don't need heat to get them out because I have a impact. I'm just a little weezy about snappin the bolt off if it's to tight in the suspension.
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
Suspension removal?
Well it might be worth it to get the skid out at all costs. Get everything taken care of and not have to worry about it at a later time. You might need new cross shafts if the bolts are that tight into them.
79 Spitfire
Suspension removal?
Yup thats the thing I just am not sure if I can still find them haha.
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
Suspension removal?
There not hard to make if you have a lathe or know someone that does. If things are that seized up the shafts might be toast also. That's worst case won't know until they come out.
79 Spitfire
Suspension removal?
Well good news the bolts came out with ease with a impact, I still have them in to hold the suspension up and will get around to dropping it sometime next week after I build my homemade workbench this weekend.
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
79 Spitfire
Suspension removal?
Well I got anxious tonight and drop the suspension. It went good, so I mover on to the bolt that hold on the idler wheel that is broke. Well the son of a ***** broke off, but I got the shaft out that its bolted on and am going to drill it and tap it sometime. Other than that everything looks ok.
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
79 Spitfire
Suspension removal?
Talk about a ***** to get the suspension lined up! Got the new idler wheel on and am now going to put the suspension back up, gonna need help tomorrow with it as I couldn't do it myself.
Jim
Jim
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
Suspension removal?
Getting it back in is always a pain. If your suspension has a front spring adjustment, back the tension off before trying to install, and of course make sure your rear idlers are as far forward as they can be.
79 Spitfire
Suspension removal?
Hey I got my suspension back on. Just wondering how tight the track should be because it is pretty darn tight.
James
1979 Spitfire 340
1980 Trailfire 440
1979 Spitfire 340
1980 Trailfire 440
79 Spitfire
- Sprailfire340
cowboy mark
Suspension removal?
i'm gonna be having the same adventure. i wore out something in my drive, and have to change either the drive gear or the main drive shaft that turns the track. will that ski fit a 1976 cyclone?...i need a ski too
Sleds owned..
1 1976 JD Cyclone
1 1976? JD Liquifire,
1 1977 JD Liquifire (parts)
1 1976 JD Cyclone
cowboy mark
Suspension removal?
I sheared off the bolts that hold the drive sprockets on the shaft..so it could end up being an easy fix.....everything in the gearbox and drive looks fine
Sleds owned..
1 1976 JD Cyclone
1 1976 JD Cyclone
