Liquifire engine question
webman
Post by webman »
I am playing with a tool that is suppose to tell you the dimensions for a tuner pipe, and was wondering if someone knows the values it is asking for for a 1980 Liquifire. I need:
Exhaust open period in deg
Main transfer port open period in deg
exhaust port diameter in mm
R Rimko
Post by R Rimko »
HI I have my 80 liquifire motor on the bench . I will deg it out and post . Rod
R Rimko
Post by R Rimko »
Well found out this motor has a mild port job. Exh width 40mm exh 200 deg . transfer 119. int 176.
