John Deere Liquidator piston's
nitro76
Post by nitro76 »
I have 2 CCW piston's P.N. 48640000. I have been told these are piston's for the 76 Dator. Can any one help me out on this?
Hi Rick,
I will check my NOS ones today to see if they have the Kiortz P/N on them.
PS: DIBS!
nitro76
Post by nitro76 »
JoeRainville wrote:Hi Rick,
PS: DIBS!
Joe you told me you were going to do this a week ago. Will the CCW and Kiortz have the same P.N.?
Sorry Rick, I had back to back snocross races and a midterm exam to deal with. Did have much time to play...
If they are CCW boxes, they might not be Dators. The first "Kiorts" branded motor was for the 295/s, and all the 75-78 motors were no longer called "CCW" But, they could have used up the boxes, so I am really not sure.
The set I have I think are for the 340/s have a mfg P/N of: 32640000
The 295/s set I have are Deere P/N AM53172, with a mfg P/N of 100000-7322
The Dator set I have are in Deere boxes without a mfg P/N, only Deere's #.
Does anyone else have an NOS set of Dator pistions?
-Rainville
340s
Post by 340s »
Hi Rick/Joe,
I have a set of updated forged pistons still in deere boxes. I can check them for numbers tonight.
Craig
As far as Kioritz Numbers on Dator piston Boxes I don't believe you will find any I went through this about 6 years ago looking at all the boxes we had if there is a number on them we didn't find any??
Nitro76, Just to make sure, that number wouldn't be 45640000 would it??
Dator76
Post by Dator76 »
i have one nos dator piston in a kioritz box says 100000-7452 0 on it. have no idea if its right box or not. dator pistons are easy to spot as they have a big wrist pin in them.
Ted
3 Liquidators
1-340/S
1-295/S
1-78 Cross Country Liquifire
340s
Post by 340s »
Hi guys,
The two NOS AM54293 std dator pistons that I have don't have any numbers on them, just 'TRW' on the inside of the piston.
The rings that also came with the pistons in the JD boxes have kioritz p/n 100002-7382 0 on the kioritz tag but then has a AM53544 sticker over that.
Craig
The Dators use a 19 mm pin
nitro76
Post by nitro76 »
ICCSF 108 wrote:As far as Kioritz Numbers on Dator piston Boxes I don't believe you will find any I went through this about 6 years ago looking at all the boxes we had if there is a number on them we didn't find any??
Kenny they are 48640000 Rick
nitro76
Post by nitro76 »
ICCSF 108 wrote:The Dators use a 19 mm pin
These have a 18mm pin
nitro76
Post by nitro76 »
Joe
Did Jake get a hold of you on that Speedway hood? I guess he won it.
Thanks Rick
Rick, That was the only number in my books that came close, so I thought I"d ask.
nitro76
Post by nitro76 »
Thanks for the help guys. I don't think these are Dator pistons.
If any of you guy's have any Rupp question's I can help you out.
Rick
Rick, I do, can You send me a direct email??
ump45-nt@swbell.net
