Light Problems?
Light Problems?
My headlight doesnt work, but gauge lights and back light do. It could have burned out, but seemed to be very bright last time it worked. I seem to have everything hooked up. Not sure I'm getting power to the light. I tested it and if I did it right there isnt power. Any known things that could be wrong?
- Danzig
- Real Name: Paul File
Light Problems?
I had problems with mine and found the problem to be from the high/low beam switch to be the problem, replaced it and it has been fine ever since. You may want to see that may be your problem.
