Here is a good one...
With the key on run I have spark on only one side. Turn the key off and I have spark on both sides.
Key switch test good as does the kill switch.
Incase it matters...74 JDX8 w/KEC440-22 engine
Japanese Gremlins
Japanese Gremlins
Re: Japanese Gremlins
Is it wired correctly?
If it's connected properly, and the switch is good, all I can think of is a bad ground. With the switch "OFF" the mag has to be grounded out! Something is not right ( like you needed me to tell you that )
I ran into an engine just like this many years ago.
If memory serves it was a bad condensor but the mind has started to run amuck at times.
I will be back at this one in a couple of days but working on the 75 400 right now.
Will let you know.
Will let you know.
