spitfire piston part numbers
augie
Post by augie »
hello, can someone help me out, does anyone know the kawasaki part numbers for pistons and rings for an 80 spitfire? thanks augie
Deere Daze
Re: spitfire piston part numbers
Post by Deere Daze »
M68588 PISTON
AM55080 RINGS
AM54824 BEARING
M68167 PISTON PIN
M68071 RETAINER(CLIPS)
:canada:
augie
Post by augie »
thanks for the info, these look like jd numbers , im in need of the kawasaki part numbers. thanks ,augie.
Augie, you'll probably need to go to the Kawasaki board ( I think it's called Kawitrax )for those kind of numbers, but they might not be able to help you either, as I think the Kawi engines that the Spitfire used was a Deere only engine... I guess I don't understand why the Deere number won't help you??
Agreed. I haven't found anyone that has a Deere/Kawasaki cross-reference, and parts don't necessarily exchange, because Deere tested the Kawasaki versions of the engines, then spec'd changes for the Fireburst version.
augie
Post by augie »
thanks for all the input everyone,the reason i wanted kaw numbers is i have access to some kaw pistons and rings. where can i get the deere parts? thanks again for the help. augie
