Comet 100-c clutch
Comet 100-c clutch
My 1974 JDX4 has a Comet 100-c clutch. Is it a good clutch? Does it have a 30mm tapered shaft? Or? Thanks.
Re: Comet 100-c clutch
It's an older version of the 102C which came out in '76 and became the industry standard. It has brass bushings, and a cover. They're fine, but the brass is often worn out, and belt dust builds up under the cover. Yes, 30mm shaft.
