340/S Replacement Crankshafts
After a long search, I have picked up a few cranks that Jerome & I have determined will probably work for a replacement crank for the 340/S motors. These cranks came out of the older CCW/Kioritz Piston ported 400 & 440 motors. The rods & lower rod bearings aren't as beefy as the OEM 340/S cranks & the crank is 0.050" shorter on the mag side as the OEM 340/S cranks are but everything else cks out to be the same.. SOOO in a pinch we believe they will work..
lynxer
Re: 340/S Replacement Crankshafts
Post by lynxer »
The 340/S sure seems to have alot of unique parts! good thing you are finding ways to keep them together!!!!
Lynxer, for sure the 340/S has a lot of unique parts. It was indeed a unique sled.
