Problem with 81 LF
Problem with 81 LF
Hi!
Yesterday i was blessed with lots of snow here,so the LF was prepered for its first run.But after a while the LF didnt have the power to run,i just give it more and more throttle but no,almost like you have the handbrake in a car and trying to drive.And it stinks fuel....but i have no fuel leaks.The LF have worked fine before so thats why im suprised. Any ideas?
My Snowmobiles:
John Deere Trailfire 440-80
John Deere Trailfire 440-81
John Deere Sportfire-81
John Deere Liquifire-81 Serial nr 160032
John Deere Liquifire-81 Serial nr 160033
Re: Problem with 81 LF
Bump! Now the carbs are clean,but when i driving it at full throttle it runs so good and fast! but when i take it slow it stinks gas and feels like before...?? I am now thinking about put a comet 102c in because now its an kawa from Invader/Interceptor and the clutch engage at 5800rpm.
My Snowmobiles:
Could the fuel pump be dumping raw fuel into the engine thru the impulse line? On my Sportfire I get a fuel smell because the carb is flooding the engine & exhaust pipe w/ raw fuel. Liquid gasoline actually drips from the exhaust pipe. On another thread I was told that jet needle & seat are not sealing correctly.
Hope this helps
John Hoover
Hope this helps
John Hoover
The same for me i think...when i smell the snow under the exhaust it smells raw fuel...O'Deere wrote:Could the fuel pump be dumping raw fuel into the engine thru the impulse line? On my Sportfire I get a fuel smell because the carb is flooding the engine & exhaust pipe w/ raw fuel. Liquid gasoline actually drips from the exhaust pipe. On another thread I was told that jet needle & seat are not sealing correctly.
Hope this helps
John Hoover
My Snowmobiles:
- guitardude081
- Real Name: Jack Durand
Have you checked your needle and seat assys? It's best to check them with a vacuum gauge. Are your power jet lines sealing? Are your needle jet o-rings new or are they used and torn up?
~Jack
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
2003 Ski Doo Renegade 600HO
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
Now ive checked everything and no luck 7000rpm and 35km/h is not right!!! And it stinks gas.........
My Snowmobiles:
Could this be a crank seal problem. What do they recommend, spray WD-40 or carb cleaner at the crank seals while the engine is idling to see if speeds up.
John Hoover
John Hoover
You can't do the spray trick on a liquifire. The seals are inclosed on both ends. You have to take the engine out and tear it down to check it. Do you know how long it has been since the seals were replaced?
Would a compression check help?
Compression no, but a pressure test would.
Now i have take the carburators apart again and cleaned them with an ultrasound wave machine?Anyway put them back and started the LF.It runs great,so i took it for a ride and everything is great,the sound the speed well everything!
But!!!! Then after 25minutes of snowmobiling it sounds BÖUUHÖ! and its the same &%#) again!!!! I was forced to run beside the sled until the rpms was high enough to sit on it and run it back home.So now im back at square one with a stinky LF in the garage
My Snowmobiles:
- Sprailfire340
Sounds like your tank needs to be drained and cleaned...it doesn't take much sediment to clog up a carb
ME
If your sled starts and runs fine for about 30 minutes and then the power really fades try replacing your ignition coil.
Mine has had this problem and I had it replaced problem solved. After starting your sled and running it until the power fades stop and let it cool down after that start it up and see if it has the same result...for some reason when them coils get hot they wont let the sled run right plus their 30yrs old....I've replaced mine twice now....
good luck
good luck
Well i have replaced the coil and the cdi box.And still the same result. But then i shifted side on the carburators.And it runs fine?????I have taken it for 2runs now and it still runs fine.But how is this possible????
My Snowmobiles:
Your carbs do fit a certain side just because of the jetting of the pto/mag side. but if it's running good now ....sweet.
did you replace the internal ignition coil on the stator plate......sounds like you did if it runs for 2 hours without bogging ....
any updates....
any updates....
