I just rebuilt the engine in my trailfire 340, and when i when to start it today i could barley turn the engine over with the rope starter. Had both the sprak plugs out when i was trying to pull it over. Could it be in the recoil, or is it a problem with the engine????
Thanks, Steve
JD 340
Re: JD 340
does it spin freely by turning the clutch side by hand if so its prolly a recoil issue if not id tear down and revisit your overhaul , i just did an 81 liquifire that seized up after about 30 minutes of run-time turned out to be the water pump I went ahead and dissassembled the entire motor and all looked great so i reassembled , after seeing it apart again after some running for a spell it gives confindence all is well inside . wade
Re: JD 340
it hangs up a bit when you turn the pully, but nothing that is unusal for the engine never had been runing. (It truns over like a tractor enginge does when you are trying to trun it with a hand crank) Has new pistons,cylinders,and new rings.
Hoping that i dont have to tear the engine down!!! Thanks steve
Re: JD 340
if it turns over easy between compression strokes id take the recoil housiing off and pull it not bolted to motor maybe it will be something simple wade
Re: JD 340
oh ya !!
