I am having an issue with my brake light on my 95 Polaris Indy XLT.
Sometimes my brake indicator light on the dash comes on and my brake light/tail light does not work. Not sure where to start on this one. I am not too familiar with how the brake light wiring works....
So any suggestions would be great!
I will start with checking all the connections and cleaning them. But any other suggestions would be helpful.
Polaris Question
Polaris Question
Re: Polaris Question
I would start at the tail light itself and check for corrosion on the contacts.
Alright....
I took all the bulbs out of the tail light and the indicator light went off.
Then re installed the running lights which cause the indicator light to go back on.
I installed the brake light only and it does not work....but the indicator stays off.
I will intall all new bulbs tomorrow and see if that helps.
Im not sure what the deal is...???
Well I installed all new bulbs and that did not help. All the bulb sockets were nice and clean. I also used di-electric on them.
So I started checking all the connections and cleaned and applied di-electric to everything....which seemed to solve the problem...but then they went out again!!
SOOO I cleaned a few other wire harnesses and they started working again. They seemed to start working after I cleaned the main harness that connects to the motor. So now they are working like they should.
Hopefully I solved the problem but I didnt really see any correded connections...
Could a poor connection in that main harness cause thre rear lights to go off??
Thanks!
Thanks!
?? Could be that one of the connections you worked on was a ground which made everything work again?? ck your grounds..
Tail light might be grounded to the tunnel??
- guitardude081
- Real Name: Jack Durand
The taillight on the XLTs plugs into the main harness just like the JDs do. One thing I would check is the brake light switch on the caliper. Make sure that it is functioning properly. The chaincase/exhaust area seems to get a lot of corrosion. There could also be a possibility of a leaky hose or caliper piston that is leeching fluid onto the switch.
~Jack
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
2003 Ski Doo Renegade 600HO
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
I checked and cleaned the connection on the light switch (on the caliper). I didnt notice any fluid leaks.
Time will tell if I fixed the problem.
How can I check the switch itself? A continuity test? If the light stops working again that could be the first thing I check.
Thanks for the ideas!!
- guitardude081
It should have continuity with the brakes on and it should show open leads when the brake is off. The older Polaris levers tend to stick a little bit. If it's sticky, pull the lever bolt out, scotch-brite it and re-install it with a light film of lithium grease.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
