sprintfire pistons
bhall211
sprintfire pistons
Post by bhall211 »
I was wondering if anybody has tried using oversize spitfire, invader pistons in a sprintfire? I have a set and am getting my cylinders bored to try it. I'm not sure if the rings will stand up or not.
guitardude081
Real Name: Jack Durand
Re: sprintfire pistons
Post by guitardude081 »
It will work but, the rings will wear out rather quickly. It's better to find NOS ones or good used ones. Wiseco used to make 340 pistons but, they stopped a number of years ago. I've got Wisecos in my Spitfire. They are single ring pistons. They're Wiseco# 2042s. They come with CDM rings which can run in Cast, Chrome or NiCaSil. If you can find a pair of those, that would be your best bet.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
2003 Ski Doo Renegade 600HO
bhall211
Post by bhall211 »
with the pistons being oversize, are the rings still designed for a chome bore? after boring the cyl. it would have to be replated. I was thinking that the rings would be designed for an iron bore, eliminating the need to replate.
