Kioritz 440LC crank rebuild?
motorhead255
Post by motorhead255 »
Can the inner bearings and seals on 76,77,78 440LC's be replaced. the reason i ask is i was reading in the service manual and it said that if they are worn out the whole crank assembly has to be replaced, and if so what does a person do about finding a replacement since i'm sure jd doesn't make them anymore
78 Liquifire 440
81 440 invader ( very fast )
JD600
Re: Kioritz 440LC crank rebuild?
Post by JD600 »
First off, Welcome Motorhead.
While i am not too sure of the avalibility of the bearings and seals, one of the sponsors of this great site is a crankshift specialist. If anyone can fix your crank, Jerome Kretzman of Crankshaft Services can help you out. Here is a link to his page. Good luck!
DE
http://www.jdsleds.com/ads/crankshaft/cs.html
