Hoping that someone can tell me the proper way to connect coil wires to breaker points. There are some insulating washers on the breaker point terminals, but I'm not sure if you are to isolate connection to the main frame/bracket of the points or to the spring portion of the assembly. I'm having a problem with not getting spark after installing new points, so I'm thinking that this could be the problem.
John
Michigan
