77 liquifire ignition problems PLEASE HELP!!
motorhead255
Post by motorhead255 »
does any one know how to test the ignition system (cdi, coils, trigger, and stator) on a 77 440 liquifire with a multi tester ( if its even possible ) or another way to do so? the reason i asked i bought a sled that sat in a bush for lord knows how long and i have no spark and i'm not sure where to start i've tryed two different cdi's already and one extra coil that came with it and no luck i noticed the tach does move when i pull it over but thats all i get. please help!!
78 Liquifire 440
81 440 invader ( very fast )
Re: 77 liquifire ignition problems PLEASE HELP!!
Go to the FAQ section and read up on the testing procedures.
lwb140
Real Name: Wade bennett
Post by lwb140 »
check your kill switches early in your diaglostic work, the kill wire on the cdi is grounded when off ,id unplug the key switch and the kill switch on the handlebars and check for spark just my .02 worth wade
