Hello All,
My 77 Liquifier has a good spark but always needs starter fluid to start after sitting for about a week. Choking it just doesn't seem to be enough. It idles and runs well enough, it just starts hard when it's cold.
If I start it every day, it starts on the first pull. I've had some advice to rebuild the fuel pump, but I could use some help in identifying which kit to buy (mfgsupply.com) - there are about 8 different kits.
I have a service manual, but the discription doesn't seem to match the description in the mfgsupply web site.
Is there a simple way to identify the correct kit without removing the pump?
thanks,
Jim
340 Liquifier, fuel pump kit identification
74 JD 300
77 340 Liquifier
77 340 Liquifier
Re: 340 Liquifier, fuel pump kit identification
This is what you want:
http://www.mfgsupply.com/m/c/07-450.html
You should also think about replacing the crank seals for proper fuel pump operation.
Thanks again for the help Harley .... and now a similar question ... how to I identify the correct seal to buy?
74 JD 300
77 340 Liquifier
77 340 Liquifier
The seals will have a number stamped on them. This is what I have found:
Mag side seal=1302, 30 x 62 x 10
PTO side seal=1301, 25 x 62 x 10
You can get them from Vendors such as Pat's Small Engine
http://www.psep.biz/store/john_deere_sn ... _seals.htm
Thanks Harley - I'll check it out.
74 JD 300
77 340 Liquifier
77 340 Liquifier
