hi guys i am wandering if some one has any pics of the battom of an 77 LF seat i want to see what was there i have a good foam but there is only two strips of plywood i want to try and fix my own seat cause i cant afford the 300 to have someone do it for me
any pics would be great thanx
76-77 LF
Re: 76-77 LF
I thought I had a picture but I can tell you that there is a 2 inch or larger strip of wood running down each side which lays inside a molded pocket of the foam. The underside of the foam is contored to fit over the heat exchangers.
Re: 76-77 LF
what keeps the foam stuck to the wood
Re: 76-77 LF
you can also cut a 1/4" piece of plywood to the shape of the bottom of the seat. Then use T nuts to fasten in the rear. Use staples along the edge to fasten the seat cover to the wood.
Re: 76-77 LF
harly if there is two strips of wood along the side how do they stay in place so they dont seperate
Re: 76-77 LF
The wood is glued with the appropriate adhesive. As 427cobra said, install 1/4x20 Stainless T nuts in the wood first so you can anchor the seat to tunnel from underneath. Since the 76/77 Liquifres use tunnel heat exchangers, you cannot use a full solid piece wood under the seat, only the side strips.knighthawk wrote:harly if there is two strips of wood along the side how do they stay in place so they dont seperate
Re: 76-77 LF
ok i think i got the idea thanx guys
Re: 76-77 LF
I'd use 3m super 77 spray adhesive
Nick
Nick
Re: 76-77 LF
When I had to repair one of my LF seats there were 2 or 3 strips on vinyl that went across the bottom to keep everything tight. Not sure if this was stock but I am pretty sure the seat was original.
Re: 76-77 LF
thanx guys
