Temp Sending unit cable pulled out on Liquifire
Does anyone know if you can repair the cable that goes to the sending unit on the engine of my 1980 Liquifire? Mine pulled out.
Re: Temp Sending unit cable pulled out on Liquifire
At one time there was a post on here on how to repair a gauge with an aftermarket probe. I didn't feel like going through the hassle of doing that, and didn't want to spend a fortune on evilbay, so I went to the auto parts store and bought a sunpro gauge instead. It was only like $15-$18. The face is different than the OEM one but it is exactly the same size and fits the hole perfectly. The probe wire(or whatever it's called) is longer, but it can be coiled up, and cable tied under the dash. Just make sure it is away from any heat source so it doesn't get a false reading. I believe in the aftermarket thread someone is selling brand new copies of the original, they wern't out yet when I bought mine, and they're a little pricey for me to change what I have.
Rob
Rob
76 El Tigre 5000 WRECKED
80 Liquifire running
80 Spitfire new project
Hi Ski,
If you look at the top of the classified page at the reproduction parts new gauges are available.
There is somebody that rebuilds the old ones but I believe you can get a new one for the same price.
Tom
Tom
these gauges are awesome i bought some at waconia for the 76-77s also if you use a metal jacketsed cable be sure it doesnt get ino any electrical stuff ,i had one shorting out againsdt the coils on my 78 with the coil cover off looked cool at night though!! wade
Thanks for the suggestions guys. I am going to look into it tonite and see how serious it is. May be something I have to scout the swap meets for this summer!
I use a Yamaha SRX gauge and temp sender, work great and bolt on direct.
I was able to disassemble sensor and am wondering if there is any way to solder together? There is what appears to be a center wire that is broken. I assume that is the "main" lead to the copper sending unit. I thought I could strip back the main wire from gage that goes into sensor and solder together then recrimp everything together again. I could turn up a new sleeve on the lathe for recrimping it. Any thoughts on that idea? I'm going to try and post a picture. If it doesn't work I'll post a link to it.
That lead is not a wire. it is a small tube that WAS filled with a gas. If you want to reuse the gauge, you will have to buy a new gauge and graft the sending unit onto your old gauge as harley mentioned above.
DE
DE
I see the dilemma here. A mere mortal like me may not have the talent and skill to perform such a delicate operation. I think I'll go the aftermarket route...and still keep my eyes open for a good operating used one or NOS at the swapmeets. Thanks for the insite guys. Once again I learned something from this site!
ChickenRat just listed some NOS 80-84 Liquifire temp gauges in the classifieds. Check it out.
http://www.jdsleds.com/community/viewto ... f=2&t=9812
DE
DE
