76-77 LF
knighthawk
76-77 LF
Post by knighthawk »
hi guys i am wandering if some one has any pics of the battom of an 77 LF seat i want to see what was there i have a good foam but there is only two strips of plywood i want to try and fix my own seat cause i cant afford the 300 to have someone do it for me
any pics would be great thanx
Re: 76-77 LF
I thought I had a picture but I can tell you that there is a 2 inch or larger strip of wood running down each side which lays inside a molded pocket of the foam. The underside of the foam is contored to fit over the heat exchangers.
knighthawk
Re: 76-77 LF
what keeps the foam stuck to the wood
427cobra
Real Name: Eric
Re: 76-77 LF
Post by 427cobra »
you can also cut a 1/4" piece of plywood to the shape of the bottom of the seat. Then use T nuts to fasten in the rear. Use staples along the edge to fasten the seat cover to the wood.
knighthawk
Re: 76-77 LF
harly if there is two strips of wood along the side how do they stay in place so they dont seperate
Re: 76-77 LF
knighthawk wrote:harly if there is two strips of wood along the side how do they stay in place so they dont seperate
The wood is glued with the appropriate adhesive. As 427cobra said, install 1/4x20 Stainless T nuts in the wood first so you can anchor the seat to tunnel from underneath. Since the 76/77 Liquifres use tunnel heat exchangers, you cannot use a full solid piece wood under the seat, only the side strips.
knighthawk
Re: 76-77 LF
ok i think i got the idea thanx guys
Re: 76-77 LF
I'd use 3m super 77 spray adhesive
Nick
S_Kyle
Real Name: Scott Kyle
Re: 76-77 LF
Post by S_Kyle »
When I had to repair one of my LF seats there were 2 or 3 strips on vinyl that went across the bottom to keep everything tight. Not sure if this was stock but I am pretty sure the seat was original.
knighthawk
Re: 76-77 LF
thanx guys
