FYI, I will be getting the M67976 hoses remade
As soon as I get a hose to give to the re-popper I will be getting the 80-84 Liquifire M67976 lower hose redone ( this is the hose that wares against the steering post)
If anyone has one of these that has the ware spot on it please send to me..
bottomsupduckclub
Real Name: Dave
Re: FYI, I will be getting the M67976 hoses remade
Post by bottomsupduckclub »
I just stripped a 80 Liquifire to start rebuilding. I know the hose is there, but what shape it's in is not clear this morning. I'll check it out & get back to you later this afternoon. Dave
JDGuy
Real Name: Guy
Post by JDGuy »
You have PM
Kenny,
If the cost isn't too bad, I could use a few of the 340/s air hoses that run from the air box down that air duct on the motor (that I am having redone).
PS: Thanks for your kind words on my CC racing thread.
T White
Post by T White »
Kenny,
Thanks for doing these, I'll take a couple when they're ready.
Tom
bottomsupduckclub
Real Name: Dave
I've got the hose in the truck if you still need one. It even has the famous rub mark :doh: . Let me know if you'd like me to send it you're way. Dave :beers;
I might be interested in a few depending on the price. I'll ask others that I know that might be interested also.
Guy's I should have a Liquifire hose on it's way thanks to Terre, " johnnycyclone "
Joe, do you have any of those hoses you want done I'm not sure if I have any?? what's the right part numbers so were talking about the same hoses.
Sprailfire340
Post by Sprailfire340 »
Kenny - I believe that 340/s hose is M65914. At one time Brian was looking for one for the MAW sled. Not sure if they found an alternative?
:sled: ME
Brian, Did you find anything that would work??
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
Kenny,
The hose with spring, goes out tomorrow, you should have it by Thursday, or Friday. FYI, I have 2 hoses, one from an 82, and one from an 83. Both have 3 wear marks on them, all 3 in the same location, they look identical. You will see this on the one I sent to you. I'm assuming this is the normal wear pattern on all 80-84 Liquifires.
Terre
