440-22 duel carb size?
- GreenFever
I am planing on building a dual carb 440-22 engine with a pipe off a 800 for my 295/S that is missing its engine. What carb size should I run? Torn between 34mm off the first gen Liquifires or the later 36mm.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 600 missing engine parts
'75 800 not running
'73 JDX4 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
Re: 440-22 duel carb size?
I would stay with the 34's, This way you can used the 2 piece Liquifire air box.. " easy to get on & off " Unless you can find a 295/S air box & then the 34's would also fit that..
I personally don't like the PJ carbs..
I did the same thing on one of my sleds. 34mm's and the dual intake from a 77 Liqifire on a Cyclone engine. Plus a narrley set of tunner pipes.
- GreenFever
Why not the PJ carbs. I have no preference just wonder what would be a better choice? Also how well does the Liquifire air box fit behind the cowl on the mid engine sleds?I personally don't like the PJ carbs..
JDT do have any pictures of your setup?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The engine is not in a Deere. I put the modified Cyclone setup in a 70 Scorpion Stinger.
