briggs and straton engine
i have a briggs and straton engine fairly new that i judt got to run and when i was driving it for the first bit it wasnt bad but now it starts to cut out like its running out of fuel but its not i think my fuel line valve is in the wrong position or is my fuel filter clogged any help would be great
if it is the suction type carb, there is a screen in the bottom of the suction tube that could be clogged with rust from the tank
how do i know its suction ? in the midle of the fuel ling it goes to the botom side of the motor and theres a vlave wit 3 various positions and another hose coming out of it so what position should it be in?
- JDXspec
- Real Name: Dustin
It sounds like you have a float carb. Is it was a suction carb, the carb would be mounted directly on top of the fuel tank. It also sounds it is a slant cylinder engine and if i remember right the valve would be stright down to be open and allow fuel to flow. The valve I thinking of is right down near the bottom of the eng on the fan shroud and theres an "o" in the middle and 2 "c" on the either side of the "o" (open and closed)
Hope this helps
Hope this helps
numbers would help again on this one, but it sounds like JDXspec knows more about this one than I do.
