Walbro carb question
75greenmachine
Post by 75greenmachine »
Hello again, Today I pulled the carb out of my '75 300 so I could replace all the gaskets. My problem is I don't know what model my carb is and I don't know where to find a gasket set for it, any help would be appreciated.
Thank you very much,
Liam
1975 JD300
2008 Polaris RMK 600
:canadasmile:
Re: Walbro carb question
The model should be stamped on the flange.
75greenmachine
The flange says that it is a WDB31, where can I find a gasket kit?
1975 JD300
:canadasmile:
I think all the Walbro diaphram carbs use the same kit. Dennis Kirk , Manufacturer's Supply, or any other catalog supply co. should have them. Also, look in the links section.
