73 johndeere 500 fuel line
i have the carb that has the pump on the carb and last year i removed fuel lines from carb now i cant remember what line went where. i just need to know the one that has fuel going thought it to the carb gos to the side or the bottom of the carb. if any one can help it will be gladly aprecatied.
Re: 73 johndeere 500 fuel line
JEROLDH,
The port on the side of the carb is for the impluse line from the crankcase. The port in the center of the bottom of the carb is the fuel inlet port. The port off-center in the bottom is for the return line.
