1974 jdx8 no spark either side.
Hey guys , I just bought a jdx8 its a 1975 has the cdi box, I need some imput I have no spark in either side , Iam thinking its the cdi box but how does one know for sure? does the stator go often? I have checked for loose wires and have had the flywheel off and it looks good ( very clean doesnt look like its ever been off before)I have a cdi box coming this week but if that doesnt work what do I change next the stator or the coils
Re: 1974 jdx8 no spark either side.
first of all unplug the kill switches they ground to kill the ignition ive seen many times the one on the handlebars will be shorted or in the off position and not able to be seen wade
I had done that , and still nothing unpluged kill switch & ignition Iam starting to think the $40 bucks I payed was to much
Yes the stator could be bad. http://www.jdsleds.com/community/viewforum.php?f=5
The good news is the rewound ones are available now. Hewtec Electronics
Before condemning the stator, follow these guide lines.
http://www.jdsleds.com/community/viewto ... ?f=5&t=289
Thanks for your imput guys, I'll be working on this project this week . The cdi box that I was supposed to get this week backfired, how hard is it to get a new box or stator for this year of sled? And what will they cost, any ideas
Go here: http://www.cdibox.com/
Prestolite stator $165 + shipping and core.
Prestolite CDI box $145 + shipping.
Shipping is FREE on CDI's in USA / Priority Mail (2~3 days in the states)...FREE to Canada as well, but much longer 14~18 days. For $20 will get it there in 4~5 days to Canada....thanks guys!
Well, I think I found the problem with the x8 of mine. I tested the stator and got no reading on the high & low coils but got the right readings on the rest of them is this sound right , both the high & low speed coils are done? anyway I ordered a stator from Hewtech It will be here next week I hope this is the problem. I just wanted to say thanks to the guys for the input, it has helped me a lot
Hey guys, I have some issues again with my x8. So far I replaced the stator, cdi box & the coils and still no spark, any buddy have any ideas? Am thinking now its is prob, something simple , but I don't know where to go from here. Any input would be greatly apprenticed.
- SpitfireKing
nothing at all...or weak...or won't start?
You have unplugged the whole hiring harness from the motor and tried that? Not just the key and kill...unplug everything from the motor to the sled..
Also if you got a new cdi make sure you read the topic on switching the wires for the coils...I may be wrong, but I know you HAVE TO on the Liquifire to get them to work...but I had lots of spark, just wouldn't start.
DId you check your flywheel for cracks or issues? seeing as almost all your motor end wiring should be new with the stator and cdi I can't figure that's an issue.....any chance you have the stator plat way out of whack?
SpitfireKing,SpitfireKing wrote: Also if you got a new cdi make sure you read the topic on switching the wires for the coils...I may be wrong, but I know you HAVE TO on the Liquifire to get them to work...but I had lots of spark, just wouldn't start.
I dont know where that came from but you do not have to switch any wires around. I have worked on a few Cyclones and Liquifires with the Prestolite Ignition. The color codes are all the same and the red primary wire goes to the PTO coil and the white primary wire goes to the mag side coil.
Are we getting the second gen. Liquifire CDI confused here?I dont know where that came from but you do not have to switch any wires around. I have worked on a few Cyclones and Liquifires with the Prestolite Ignition. The color codes are all the same and the red primary wire goes to the PTO coil and the white primary wire goes to the mag side coil.
I remember reading that there was an issue with wire colors on aftermarket CDIs last year or so, for the Kawasaki engines. For the record I haven't experienced it yet.
NIck
ive had cdi boxes where the red and white coil wires were switched tons of spark just at bdc
They must have been aftermarket. The NOS cdi boxes are correct.lwb140 wrote:ive had cdi boxes where the red and white coil wires were switched tons of spark just at bdc
