1973 300 tail light issue
mikes47jeep
Post by mikes47jeep »
I'm having an issue with the tail light on my 300
With the headlight switch off I have brake light
Then when I turn on the headlight switch, the headlight comes on, but I have no tail light, or brake light
I looked under the dash and the harness doesn’t look butchered up (no electrical tape or splices)
Dose anyone have any hints, or a wiring diagram for a pull start 300??
1973 John Deere 300
1979 John Deere Spitfire
Re: 1973 300 tail light issue
Got the wiring diagram on the site, and you can also find the service manual on webman's site: http://www.jdsleds.com/tech/wiring/73wiring.jpg or http://www.vintagesnow.com/John_Deere.html
If the wiring looks intact, maybe a switch has been wired incorrectly? Check the wiring diagram against what you have hooked up to the light switch, brake switch, and tail light.
I am going to take a stab at this and say that you have lost the ground connection on the taillight housing. Black wire that goes the the tunnel from the rear light.
Invader440
Post by Invader440 »
JDT wrote:I am going to take a stab at this and say that you have lost the ground connection on the taillight housing. Black wire that goes the the tunnel from the rear light.
I have to agree with this from experience. Start with the ground connection and go from there.
