1976 Liquifire
dap574
Re: 1976 Liquifire
Post by dap574 »
High praise for Scott's cdi and stator!!! Can't wait for snow for more testing! Dave
JDMIKE8100
Re: 1976 Liquifire
Post by JDMIKE8100 »
Last week put in different stator from a Cyclone.
New exterior coils and new Hewtech CDI.
Have spark.Put engine back in sled,check for spark,still a go.
Try to start,no go,check for spark and none.
Am I missing something obvious,don't want to pull this thing apart again.
Kill switch has been cut by previous owners,tried with ignition switch disabled also.
Re: 1976 Liquifire
ARe you using new spark plugs?
JDMIKE8100
Re: 1976 Liquifire
Yes,brand new set,NGK.
Tried cranking again this morning,had spark for about 5 cranks.
Lost it on mag side first,then PTO side.
Suspect a ground problem.
Re: 1976 Liquifire
JDMIKE8100 wrote:Yes,brand new set,NGK.
JDMIKE8100,
I would start at the coils checking to see if all the mounting screws are clean, rust free and also that the grounding lead from each coil is clean and rust free. I would also check the grounding wire from the right side coil to the CDI box is clean and rust free. There should also be a copper strip mounted between the center of both coils.
If you are unsure of the condition of the stator mounting screws, remove the flywheel to inspect.
JDMIKE8100
Re: 1976 Liquifire
All coil conections were cleaned when new ones installed,copper strip is there.
Previous owner had a ground going from right coil to bolt on recoil.
Should there be a braided ground from right coil to CDI?
Re: 1976 Liquifire
The coil ground wire attached to the bolt on the recoil should be attached to either one of the CDI box mounting bolts.
The ground cable was not a braided ground, just a heavy duty insulated wire with crimped on ends.
JDMIKE8100
Re: 1976 Liquifire
Moved the the coil ground to the CDI bolt.
Still no spark,thinking got to pull the motor again and recheck all the wiring.
This is giving my patience a good test.
Re: 1976 Liquifire
you don't have to the pull the motor, it is possible to get the outer housing off in the sled.
