Spitfires, Good, Bad, & Ugly
spitfireguyII
Re: Spitfires, Good, Bad, & Ugly
Post by spitfireguyII »
my spitfire has a rubber track on it. i guess it is a little bit shorter then a spitfire track because who ever put on had to drill holes about an inch ahead of each hole for the skid frame.but the drive pitch is the same and the wheels line up with the inside lugs. seems like it will work. this is a project spitfire i baught for somethign to work on when i am board.
currently own: 83 sprintfire
80 spitfire (basket case)
have owned: 78 spitfire
80 spitfire
77 300 green machine
80 liquifire
Hawkeye
Post by Hawkeye »
I am guessing the dropping cylinder is the result of a bad CDI. A pretty easy fix, but costly ($100), considering the overall price of a used spitfire ($300-$700). If you go this route, make sure you get the right CDI, there are less expensive ones out there but you get what you pay for. I spend one whole winter, going through the entire engine after buying a cheaper CDI. I ended up with a great little power plant, 2 or 3 extra butterfly carbs and one cheap CDI that was bad out of the box. Once I got a "good" one, that little Spit runs like a champ. Its almost more fun then my XF7, oh wait, the Spit is for the kids... Get it you won't be sorry!
metrodoggreg
Post by metrodoggreg »
Pick mine up on Friday remember riding by a dealer in cambridge minnesota across from dairy queen and dreaming about riding one well it only took 30 years lol I will be riding it next weekend hopefully they get there butts in gear and groom some trails in marshall county! :trackdown: :sled:
Greg
77 440 & 340 LF
76 LF
80 Spitfire
71 caribou
73 & 74 tigre's
70 Panther
71 puma mod custom project
73 pink lynx custom (daughters
DLDeere
Real Name: Howard Olson
Post by DLDeere »
I really like mine! It's a wild one. Not a leisurely ride, you have to be hanging on! They can be very squirrely on ice and hard pack, easy to wipe out.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
