Can a 340/5 be bored to 440
GreenFever
Post by GreenFever »
I am working on rebuilding a 440/5 for my '75 600 and I found a set of standard pistons and rings but I am unsure if the jugs I got will clean up and still be standard size. So I was thinking of getting a easier to find 340/5 engine from the salvage yard and boring it out to 440 size. Would this work? I was also wondering if pistons are swappable between all the CCW piston port 440 engines?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 295/S x3 missing many parts
'74 300 not running
'75 600 missing engine parts
'75 800 not running
'73 JDX4 not running
'74 JDX6
'75 JDX8
Re: Can a 340/5 be bored to 440
No, there would not be enough cylinder lining left to use. You're talking about an 8mm difference. I don't think good used cylinders should be that hard to find.
I'm not sure if the pistons are all the same, but they could be.
lwb140
Real Name: Wade bennett
Post by lwb140 »
loose is fast !! the iron jugs have to be really really worn or have to have been damaged or rusty to not clean up at std . tasky has some pistons for sale for this motor . my 340/s motor had been layingh in peices under the eve of a minibarn and those jugs cleaned up w/ .007 clearance with new std. pistons hope this helps wade
GreenFever
Yeah taskys pistons are the ones I am getting. So it looks like the jugs will clean up at a standard bore then.
Next question, someone really chewed up the threads on the flywheel side of my crank and I am not sure if it can be fixed. So will an older KEC 440/340 engine crank work in a KEC 440-5? I ask this because there are no KEC 440-5 or 340-5 engines at the local salvage yard but plenty of the older KEC 340 400 and 440 engines.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
A '72 crank will not work, as it has a smaller output shaft, but '73 and on should interchange.
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
If you chase the threads with a Die you might be able to salvage it.
