All,
Before purchasing this sled I would like to benefit from some of your experience. The 1979 JD Spitfire looks and runs great. Might I have as much positive and negative information that would sway my decision?
Thank You
1979 Spitfire
Re: 1979 Spitfire
I like the spitfire's, they are a snappy fun little sled. Also easy to work on.
- 2 1970 Moto-Ski MS-18
2 1969 Mercury 250ER
2 1971 Evinrude Skeeter
1 1979 JD Spitfire 340
1 1980 JD Trailfire 440
1 1976 JD 400
1 1974 Scorpion Whip
1 1989 Ski-Doo Formula MX/LT
1 1994 Ski-Doo Formula STX
- 80spitfire
- Real Name: Brian Kottke
Re: 1979 Spitfire
I have a 1980 Spitty that I restored and I must say they are just a blast. They're such a spunky little sled. Also like kreechur said they are real easy to work on too.
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
Re: 1979 Spitfire
IF your a BIG guy or wanting a FAST sled ( about 45 MPH ), a Spitfire probably isn't what you want, They do however have plenty of Power, like previously said they are a blast to drive especially in deeper snow..
Problems Are: OEM tracks are not easy to find, ( some people have updated to newer tacks but I don't know the results or problems doing so ), & the drive bearings need to be watched & replaced as preventive maintenance as when they go out they usually take the front drive shaft with them..
Just my $.0735 worth
Re: 1979 Spitfire
It is all about track condition on this sled.
If the track is bad you are going to have to find a replacemnt and they are not cheap.
- SpitfireKing
Re: 1979 Spitfire
yep #1 easy to work on...no chain case to mess with so those problem bearings are a pretty easy job, but if that track is hooped then walk away. I have about 4, unfortunately I haven't got any running right now...need a few gasket sets etc.
Re: 1979 Spitfire
In other words you would not recommend for circle track racing (antique sleds in 340 class).
Re: 1979 Spitfire
I guess it would depend on the length of the straightaways of the track, Like I said the top end just isn't there, Now IF you put a 102 comet on there or a 108 overdrive clutch on you might pick up more speed that way? BUT I'm not sure IF there is enough clearance to put one on the engine ( clearance between the clutch & the front spindle or sub-assembly etc. )
Re: 1979 Spitfire
The operator weight would be approx. 225lbs. Would this amount of weight take the Spitfire out of the running? By changing the clutch can I keep the jump at that weight and increase overall top end?
