Im working on my brothers 74 JD 400, that has no spark, so I bought some right size bolts for my flywheel puller, threw it on thought it would pop right off, Not a chance
So what do you guys suggest to get this thing off. Ive never had flywheels on this tight before, I broke my darn puller trying to get it off. All I use is a harmonic balancer puller.
Any ideas
Flywheel Removal JD 400
Re: Flywheel Removal JD 400
When the puller is installed and tight, tap the end of the puller with a hammer.
Last resort: Use a LITTLE heat on the end of the crank. Stay away from the flywheel, as the heat could melt the glue holding on to the magnets.
Thanks, Im gonna pick up a craftsman puller that way if it breaks again I can replace it free, I wont buy a harbor freight one again
It doesn't have a Ring Gear does it? if so you'll have to remove the fan tower I believe..
Sure does, already got that taken off, Im a cat guy, but I got my brothers pair of JDs while hes in alaska, im getting them tuned up and dialed in for when he comes home the end of next monthICCSF 108 wrote:It doesn't have a Ring Gear does it? if so you'll have to remove the fan tower I believe..
i bought a puller from dk last winter and destroyed it on about the third flywheel i pulled what a peice of crap . i use a harmonic balancer puller that came from napa i think .i use black socket head bolts from the hardware store to bolt to fltwheel . ive only had one i havent been able to get off with a reasonable about of puller tension and a little beating on the puller screw .
OK just making sure, as sometime that is forgotten..
- Real Name: Howard Olson
I had a tough one the other day on my 600. Impact wrench on the puller helps. Crank it tight, hit it a couple times with the hammer then crank it tight and hit it again. Did that a couple times Then I sprayed it with wd40 and let it sit for a day. Put heat on the flywheel near the shaft, repeated the above and it popped loose.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
