latest 340/s
Re: latest 340/s
It sounds like you've gotten yourself a genuine racer. Just can't figure out where it came from. Email me the serial number to bison1112002@yahoo.com and I'll see what I can find.
Re: latest 340/s
brock sounds like youve got a great project there how is the motor hopefully all there !! does it run or turn over ?? wade
Re: latest 340/s
Re: latest 340/s
Thanks Matt for posting that!The engine turns over great ,feels like it has decent compression(hard to tell just by hand)it is missing stator,so i cant get a compression check yet.It has 1123 miles on it .Covers are all still in tact, not cracked,all the air ducts still there,carbs,missing the hose that goes from the fan duct to the air box ,if anyone has one let me know part #65914.Got my parts book today Man i feel like a genius now.Thank Brock
Re: latest 340/s
Thanks Matt for doing that for me..
- HoosierDeereMan
- Real Name: Troy Miley
Re: latest 340/s
Brock,
Great find! Very nice original survivor.
Troy
Troy
Re: latest 340/s
Brock, is the cover with the sled?
Re: latest 340/s
Yep its lying there with the seat foam,But it looks like a big rats nest ,i didnt even look at it that much but i could tell it was junk.Not even sure it was a deere cover.Brock
Re: latest 340/s
Hi Brock,
Just wondering if there was foam under the tank cover? I am re-doing my CC tank cover now but don't know if there should be a layer of foam between the CC tank and cover or not. Could you let me know?
Craig
Craig
Re: latest 340/s
Craig, if you're referring to the 340/S dual fill tank then yes there is foam between the cover and tank. I might have a picture somewhere but it's about an inch thick as I recall.
Re: latest 340/s
John's should have the Pattern & the thickness of the foam
Re: latest 340/s
Hi Don/Kenny,
Thanks for the replies.
Kenny, I did buy foam from John for the tank but the cover is such a tight fit that it seems to buckle around the fill spouts when I stretch the cover forward to snap it on. At first I thought the tank was not far enough ahead but it is as far ahead as it will go. So that's why I thought maybe there wasn't supposed to be foam.
Looking at it closer, I see the cover is hitting the back of the 2 fill spouts too soon and that makes it too hard to stretch the cover forward to the snaps. It almost seems like the holes in the cover ohn made are just a 1/2" too far back and that makes it a real stretch to get the cover to reach the snaps in the front.
Maybe it's me though. Don, did you really have to stretch the hell out of the cover to get it to fit? I suppose I can get it to fit but the snaps won't hold it then and the cover will look odd since it won't go around the fill spouts evenly. Did you have to use some indutrial strength snaps to hold the cover on? Any suggestions are welcome!
Craig
Craig
Re: latest 340/s
Well, I remembered in 74 when the tank and cover arrived it fit like a "saddle on a sow". We had to cut the material around the fill openings to make it fit. Sooo, knowing that, it was the only time I did not use a "John" product but took it to Fort Wayne and had it custom made. WAY LOTS OF $$$$$$$ but a great job. DA
Re: latest 340/s
Every old cover I've seen for the twin fill tanks has about 1" - 2" slits cut in the filler holes so that the material goes up the spout when put on & probably like you say then it fits the holes better??
Re: latest 340/s
Thanks Don and Kenny. I feel like I'm on the right track now. I'll take it to an upholsterer here and get an adjustment done on the holes. That's no no big deal to get done.
If anyone is getting a CC tank cover from John you might want to ask him to place the holes back an inch or so to allow the cover to fit better. At least that's situation in my case. Thanks for the help!
Craig
Craig
