![Angel :angel:](./images/smilies/eusa_angel.gif)
Steele tunnel trailfire
Hey guys, Today while on a parts search I came across a steele tunnel trailefire. I now that this is not all that rare but it is the first one that I have ever seen. It is a 79 440 with a build date of 10/78 it is not by any means nice but it appears to be complete. I have a 79 440 trailfire with a aluminum tunnel so it seems odd that both would be produced in the same year. Does anyone have any info or knowledge about this? The sled can probably be had for around a 100.00$ but if its nothing special probably not worth it because I will more than likely have to buy more than one sled just to get it out of its spot. Any info would be great! Jamie ![Angel :angel:](./images/smilies/eusa_angel.gif)
Re: Steele tunnel trailfire
the 79s are steel the 80-84s are aluminum 79s were built in 78 the 80s built in 79 and so on wade
I think the steel tunnels will eventually be hard to find in good shape. The ones I have seen have holes..etc
If you can get a nice steel tunnel TF I think it would be a nice find.
Hi Jamie,
Wade is correct. The 79 model year Trailfire, produced the the fall of 78 all had steel tunnel. This includes both the 340 and 440's. For 1980 - 84's, the tunnel was aluminum rivited to a steel bulkhead. And Eric is right, non-rusted 79's are getting hard to find in good shape.
The 79's, while not rare from the amount build (over 8,000), do not have the highest survival rate, and the are the first of the "New Breed of Deere" too. That makes them kind of cool in my book.
I hope this helps,
-Joe Rainville
I hope this helps,
-Joe Rainville
i too have the steel tunnel 79 trailfire
my wifes sled ,shape wise scale of 10 being perfect its a 9 with a coil over gas shock in susp.
what was the purpose make a steel tunnel cost? all my ealier ones all alum.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
79 TRAILFIRE 440
79 KAWI INVADER 440
- 80spitfire
- Real Name: Brian Kottke
I was always told by an ex-John Deere mechanic and racer that the purpose of making them Steel was, they were concerned about if the aluminum would be able to handle the stress of two people riding on it at the same time; this, however, ended up being something that they didn't need to worry about. Atleast Deere was looking out for everybodys safetyRAT540 wrote:i too have the steel tunnel 79 trailfire
![Clap :clap:](./images/smilies/eusa_clap.gif)
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
If I have my story straight, I thought one of the Deere engineers told me it was because they needed to re-use a huge welding machine and fixture that was purchased to weld the steel tunnel for the 73 JDX-4. Accounting needed that capital equipment used again.
If any of the Horicon members like Ed Kruel or Dick Teal can set us straight, that would be appriated!
-Joe Rainville
-Joe Rainville
I believe Dick Teal told us that story at Robert Carlson's Induction party. The suits told them they hadn't justified buying the machine, so they used it for one last run. I've always wondered if it was used in the lawn tractor fabrication, or if it was just sleds.JoeRainville wrote:If I have my story straight, I thought one of the Deere engineers told me it was because they needed to re-use a huge welding machine and fixture that was purchased to weld the steel tunnel for the 73 JDX-4. Accounting needed that capital equipment used again.
-Joe Rainville
- 80spitfire
I'm not gonna lie that's a way funnier reason to make em steel lolJoeRainville wrote:If I have my story straight, I thought one of the Deere engineers told me it was because they needed to re-use a huge welding machine and fixture that was purchased to weld the steel tunnel for the 73 JDX-4. Accounting needed that capital equipment used again.
-Joe Rainville
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
