300 compression
sd300
300 compression
Post by sd300 »
95 and 105 wide open throttle chock open
thinking I need to put rings in?
thanks bob
sd300
Re: 300 compression
Post by sd300 »
how low can commpression be and still not have running problems
Do I need to think about rings or something at this compression 95 and 105
Thanks Bob
sd300
Re: 300 compression
Post by sd300 »
It does not pump fuel well even after carb pump kit installed. only runs for a short period of time with the choke half closed.
Re: 300 compression
Generally with compression as low as yours the engine needs attention. The low compression along with bad crank seals is causing the hard start and fuel delivery issues. You could have bad head gaskets, worn cylinders and worn rings. You won't know until you tear it down and inspect everything.
Re: 300 compression
I agree with Pat.
Those Kohler engines are easy to fix.
