exaust leak liquifire
3JDTIM
Post by 3JDTIM »
got a 1982 liq with a leak in exaust where the two pipes meet how do i seal it up ?
monte44
Re: exaust leak liquifire
Post by monte44 »
That is a very common problem. A good bead of high temp rtv works best and let it dry before restarting the engine.
JD_Sledder68
Post by JD_Sledder68 »
My 78 LF leaks a bit at the exhaust manifold/pipe connection as well. You separate the two, and run a bead of the RTV around the inside of the exhaust manifold socket? Will a small leak hurt the engine?
Brian Redick
1978 John Deere Liquifire 340
Hackinator
Post by Hackinator »
I had the same problem. I used Permatex Ultra Copper High Temp RTV. Issue resolved.
Danzig
Real Name: Paul File
Post by Danzig »
silicone will not work, dont even bother. It will blow out, if not today, tomorrow it will. I have never found a cure.
Hackinator
Danzig, I stand corrected. Silicone blew out this afternoon. My apologies for passing on bad information. I'm thinking one could braze around coupling on the exhaust manifold and build up enough to prevent a leak. Or perhaps some kind of lead exhaust gasket.
Danzig
Post by Danzig »
Welding, brazing, wont work. vibration will break the pipe eventually.
good luck
I have found that the more you ride it, the more of the oil burns off and its not too bad, warm temp running really makes a mess vs. cold temps
