80 Liquifire - Engine boggs out after 20-30 minutes
If anyone can help me with this I'd appreciate it.
I have a 1980 Liquifire, after getting it started with a little starter fluid it seems to run well for about 20-30 minutes. At that point the engine begins to bogg out and the sled will not move. Of course the sled has gas, the track and drive parts are free of problems. Seems to be more of a engine issue.
I've been told the CDI could need replaced because it's heating up and not working, not sure??? Otherwise I have no idea. It seems strange that the sled runs very strong for 20-30 minutes and then seems to totally die. Once it begins to bog out the sled will putter and then quit, at that point it can't be restarted until cooled. Any ideas?
If you have any ideas of how to fix and correct I would appreciate the feedback.
Mike
Mike
Re: 80 Liquifire - Engine boggs out after 20-30 minutes
Mike-
Same thing happened to my 80 liquifire and once I replaced the CDI box it never did it again. So I would assume you have the same issue.
I would ride for 20min and when I would come to a stop, it would bogg down to 1500 rpms and eventually die out. Once I would wait for awhile it would fire right back up on the first pull...
Keith
Keith
1984 Sportfire..Work in Progress!
Sounds like my issue exactly and I have another new CDI box. I'll try it. Thanks.
Must be the stator cause the sled will fire right up after it cools?
Try disconnecting the rev limiter.
Actually I have a new coil pack that is not installed and not a CDI.
Is is wise to invest in a new CDI or work with the stator? I should say that the sled doesn't want to start on it's own when cool easily. It needs a little starter fluid to get going, but once running it's very strong.
Thoughts?
Thoughts?
- Real Name: Keith Bylin
Our 82 LF did/does the same thing (82+ LF has a different ignition) . Changed CDI Box, rev limiter, and now the stator and flywheel. Giving it the hot run test this weekend. The stator pulse coil had been soldered in by a quack, flywheel distorted and chipped magnets with a 'jaw puller' and a burned spot on the underside, so it has seen better times.
Change out the easy parts first, as the stator remove/replace is a pain. Ohm readings are on this site for stators too. Course you will have to take two readings- cold & hot.
Good luck! Electrical is for me at least, takes up so much time to trace and fix.
kb
kb
- Danzig
- Real Name: Paul File
After 20-30 minutes you say it bogs and dies and wont start.
Is there spark ? Is fuel getting to the carbs ? Will it actually start and run; but poorly ?
Actually once started the sled run great with lots of power. It does have spark, compression is strong. Seems to be getting more than enough fuel b/c it goes through a tank very quickly, not fuel efficient at all.
But seems like an electrical problem.
- Danzig
Stator or CDI in my opionion, sounds like a heat soak problem
- Danzig
got the http://www.arcticchat.com or http://www.articinsider.com
look for a person who goes by KEV, he will rewind your original stator, tell him Danzig sent you.
http://www.statorkev.com/index.html
Thanks for the help. Going to start with the CDI and move to the stator.
MK
MK
