1974 jdx8 no spark either side.
Re: 1974 jdx8 no spark either side.
Try switching the spark plug wires around.
joshua16
Real Name: joshua
Post by joshua16 »
i have a 1974 jdx4 special and i had no spark in ether side so i pulld my flywheel off and dough all arownd and could not figure out wy there was no spark so i put it back together and pulled my external coils off and the connectors were cerroded so i cleaned them up and i had spark i dount now if you try it but it worked for me.
NO MONEY NO FUNNY
hauberg41
Post by hauberg41 »
the plugs are wet , after trying to start but then I will check for spark and there still is spark. do you think it could be the voltage regulator? I will switch the one I have out of my 74 scorpion cause I know that one works ( cause that sled starts ) other than that,Iam starting to think that the JD is possessed
joshua16
Real Name: joshua
Post by joshua16 »
i have a 1974 jdx4 special and i had no spark in ether side so i pulled my flywheel off and dough all arownd and could not figure out wy there was no spark so i put it back together and pulled my external coils off and the connectors were cerroded so i cleaned them up and i had spark i dount now if you tryed that or not but it worked for me. :letitsnow: :needsnow: :thinksnow: :sled: :winter: :usa:
NO MONEY NO FUNNY
