where can I buy parts for the 300, I going to pull off the heads and check cylinders.
Need head gaskets possiable rings crank seals base gaskets?
I work at a local john deere delership so I can probaly find rings but the gaskets and seals I would like new instead of nos parts
Thanks Bob
300 parts?
Re: 300 parts?
Bob 35 year old seals will be dried out and hard.
Buy new seals and gaskets.
The Kohler parts are readily available.
MFS has them as does Pat's.
Where are you in SD? I live in Milbank.
Re: 300 parts?
Iam in Watertown,
Thanks for the info
Ill tear into the engine soon as its above 0 outside
Thanks Bob
Thanks for the info
Thanks Bob
Re: 300 parts?
At the rate we are going this winter Bob, that will be in June.
