I've had it for around a decade and got to put 3 miles on it. I'm tired of working on it. It has new points and condensers, one new coil (the old one turned out to be good, so there is a spare). New fuel pump. New crankshaft seals and cylinder, head, and manifold gaskets. I'm not sure what I did wrong putting it back together, the left cylinder only has 85 psi compression. The right cylinder has 150 psi. It backfires so much it can barely make enough power to move. I haven't started it since last winter, it would fire up after a few pulls then.
The seat is toast, and the backrest has rusted off. But the body, frame and track all seem to be in great shape. Lights work, speedometer works.
I'm not sure what it's worth, so let's say $500 or best offer. And if you want it, you have to pick it up in Piqua, Ohio.
Joe Kimball
joneilkimball@yahoo.com
937-336-4652
http://s374.photobucket.com/albums/oo18 ... nowmobile/
'73 600 for sale
