77 Liquifire
- 80spitfire
- Real Name: Brian Kottke
77 Liquifire
So I went to Waconia this week and I brought home a new Deere. I found a really nice 77 Liquifire 440 that has been really well maintained and actualy restored at one point in time. The sled has a brand new track, fully rebuilt motor, new bearings all around and a recovered seat done by John's upholstery. I was pretty dang syked to bring this thing home, it's really nice. All that I need to do to it is get the carbs setup a little better for the low-end, but other than that she runs great.
I was wondering what you guys all know about the 77s and what I have to keep my eye on and look out for for general maintenance. Also I was wondering if anybody has any operator or service manuals for my sled.
Thanks guys,
Brian
Thanks guys,
Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
Brian,
The 77 is a more refined verison of the 76 but still with the same rear suspension. Keep the carbs clean and adjusted properly. Check the coolant level and the water pump belt. A copy of the owners manual and service manual is online...
http://www.vintagesnow.com/John_Deere.html
Re: 77 Liquifire
great find!! sounds like all that one needs is a butt on the seat!! wade
- 80spitfire
Re: 77 Liquifire
Exactly! lol I actualy just got done plowing snow and I went fro a quick 15 mile cruise on it. I did learn today though that cleats aren't quite as good in powder as my 144" Polaris lol I think the only thing I need to do to the sled is clean and adjust the carbs, they seem pretty boggy in the low-end. I'll get her runnin like a Deere.lwb140 wrote:great find!! sounds like all that one needs is a butt on the seat!! wade
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
One thing you could do that a former member mentioned is to install 2.0 slide valves in the carbs. This was from a Service Bulletin.
Re: 77 Liquifire
harleysportster what would that do
Re: 77 Liquifire
it would help solve your low end bog. What idle speed do you have. I like to keep mine up around 2300-2400.
- 80spitfire
Re: 77 Liquifire
Ok cool I'll have to look in to it. My idle speed is set around 2200, give or take.harleysportster wrote:it would help solve your low end bog. What idle speed do you have. I like to keep mine up around 2300-2400.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
My mistake, the '77 440 Liq already has the 2.0 slides. You should verifiy that you have all the correct jets.
- 80spitfire
Re: 77 Liquifire
Haha ok no problem I'll look into it. I think I mainly just need to dunk the carbs and readjust the low-end.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
i messed with a 78 lf today . i spent quite a bit of time to get a low end bog out as well . i ended up with the idle screws out 1 turn after cleaning and piddling with them , i thought i had clutch issues but i was able to pretty well tune the dead spot out of it . it still needs some miles put on it ...but
- 80spitfire
Re: 77 Liquifire
I just got back from driving the Liquifire about 30 miles in the dark, I've put almost 70 miles on it since I bought it on saturday lol Anyways I still have the low-end bog that I haven't had a chance to tinker with yet but I also noticed that my headlight acts really funny. The beam changes all night from bright white to yellow, it usually stays yellow but if you play with the dimmer sometimes it will help it get brighter. So I'm wondering if you guys think my dimmer switch is just taking a crap on me or what it is; could it possibly be voltage regulator? Also, I've never had a liquid cooled Deere so I was wondering about the type of antifreeze to use in it, do I just use anything? and when I fill it do I fill the reservoir all the way to the top? Thanks guys and sorry for the long post.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
I can just about gaurentte that your headlight problem is a bad ground.
- 80spitfire
Re: 77 Liquifire
That was another thing that I thought it might be. The reason why I thought maybe the switch, was because the rubber is cracked, so I thought moisture could get in. Do you happen to know where all the grounds are on this thing? I just don't know this sled well enough yet.JDT wrote:I can just about gaurentte that your headlight problem is a bad ground.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
There is a wiring diagram in tech section of this webite.
First thing to do is inspect you sleds harness to see if any PSO has modified any wiring.
If so I would put it back the way it is suppose to be as Deere Enginerres knew what they were doing.
