77 Liquifire
- 80spitfire
- Real Name: Brian Kottke
Re: 77 Liquifire
Anybody know about the coolent?
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
Standard 50/50 Anti-freeze mix.
- 80spitfire
Re: 77 Liquifire
Ok cool thanks. Do you just fill he reservoir all the way to the top? Sorry for all the questions, It's too new of sled to me< I don't have any books printed yet.
Brian
Brian
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
Re: 77 Liquifire
i have a 77 LF as well, low end bog is a hard to get rid of. i also have the crazy low light, sometimes bright light issue. yes, i would consider the switch. as a rule 90% of failure is ground related, in this instance a poor connection in the switch was my problem. changing from low to high beam multiple times helped. must have been coroded from time. i was advised to raise idle to 2800 to 3000 rpm. now it doesn't load up @ idle.
I Farm! YouEat!
77 Liquifire 440 (2)
77 Cyclone 440 (2)
76 Cyclone 440
77 Cyclone 340 (2)
82 TrailfireLX 440
85 SS440 Yamaha
77 Cyclone 440 (2)
76 Cyclone 440
77 Cyclone 340 (2)
82 TrailfireLX 440
85 SS440 Yamaha
- 80spitfire
Re: 77 Liquifire
Well I went out to the garage tonight and topped off the antifreeze on the Liquifire, I also bought some dielectric grease today and I poked around the sled for all the grounds and I think I found it, there's a ground connected to the voltage regulator and the bolt was really loose; so I tightened it up and squirted some grease on it and I'm hoping for the best. I haven't tested the sled yet, as it's a windshield of -30 at the moment. Tomorrow I'm gonna take it for a spin and test the light and tune the carbs. I think I'm gonna set up the idle too because mine is idling at 2300 so I should probably bump it up a bit.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
