hey all. i have what i think is a comet 94C clutch. it has 9 weights in it. can't really see any color on the spring. no p/n or any writing that is visible to me. the weights have numbers, so do these pucks have to go in a certain order?
So expertise would be great!!
comet 94C
Re: comet 94C
Any way you can weigh the weights on a small scale? They need to be matched in sets of three, if they are of different weights. If all the same weight, they can go in any order as long as they are oriented correctly. Here's a good read:http://www.bayshorecad.com/Sleds/Litera ... 0Guide.pdf
Re: comet 94C
they are number:
1 x2
2 x2
3 x2
4 x3.
hole size is 3/4" so weight should be the same. correct?
1 x2
2 x2
3 x2
4 x3.
Re: comet 94C
Wow.
Where is the guide like that for my 102C (Sprintfire)?
Re: comet 94C
Are they an off white color? If so, I think they are right around 20gr each. I believe the Spitfire's equipped with the 94c ran 9 of the off white pucks as stock. I have several pucks with different #'s on them, but they all weighed out equal on a scale. I think it may be just a mold number. I'd try and weigh them to be sure, just so you don't end up off balance.jdfan wrote:they are number:
1 x2
2 x2
3 x2
4 x3.
Re: comet 94C
think i will do like you said and weight them to be safe!!
Thanks guys.
Thanks guys.
