points for a jdx 8
snow7
points for a jdx 8
Post by snow7 »
I am having a very difficult time finding the correct points for my "74 JDX 8 . I have ordered all of them listed for ccw from mfg supply and none are correct also tried some Nos parts from ebay which are not correct either Same as some from MFG supply though. Just wondering where I can look or what I can do. The sled has been totally restored by a previous owner but he gave up on it cause he lost spark I got spark on one side and have the other narrowed down to the points because they are uneven and dont close properly any help would be appreciated
"72 JD 500
"74 JDX 8
2- "76 cyclones 1 340, 1 440
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
JD600
Re: points for a jdx 8
Post by JD600 »
The big question is does it have Kokusan or Denso ignition? The easiest way to tell with the flywheel off is to look at the generating coils (the top coils on the ststor plate). Does it have a one piece generating coil, or a two piece generating coil? If it has the one piece coil, you have yourself a Denso ignition. If it has the 2 piece coil, you have a Kokusan system.
snow7
Post by snow7 »
It has a one piece coil it also has ND stamped on the flywheel if that means anything
"72 JD 500
"74 JDX 8
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
JD600
Post by JD600 »
If i recall correctly, these are the correct ones for that ignition.
http://www.shadetreepowersports.com/cgi ... Processed=
snow7
Post by snow7 »
So I guess was wrong the top coil is a two piece are the points going to be the same it does have
ND stamped in the flywheel though
"72 JD 500
"74 JDX 8
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
It should look like this.
Found out last night that my points are wore out. I can't get the required .014 gap, so I assume the rubbing blocks are beyond spec..
X8 Feb 1, 11 001.JPG (189.01 KiB) Viewed 916 times
snow7
Post by snow7 »
that is what mine looks like I ordered the points on shade tree yesterday so hopefully those are correct Thanks for the help
"72 JD 500
"74 JDX 8
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
If they don't work out for you, let me know I think I have some stashed away.
DLDeere
Real Name: Howard Olson
Post by DLDeere »
So is that a Kokusan ignition?
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
DLDeere wrote:So is that a Kokusan ignition?
No, the sled in question has a Nippon Denso ignition.
snow7
Post by snow7 »
The points on shade tree were not the correct ones just wondering if anyone else has any source to get the correct points for this sled. Thanks for any help
"72 JD 500
"74 JDX 8
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
The Denso points were used on 72-74 500, 600, X 6, X8. The CCW part number is 25000450
I just ordered from here: http://www.partsreloaded.com/Snowmobile ... 25-0004-50
snow7
Post by snow7 »
I will try those hopefully they are correct. I am getting a wide range of spare points so that is good I guess. Thanks to everyone for the help. It is hard to find help on these sleds and this site helps a lot.
"72 JD 500
"74 JDX 8
"82 Liquifire
"81 Sportfire
"79 Trailfire
"80 Trailfire
"10 AC M-8
"06 AC Crossfire 7
S_Kyle
Post by S_Kyle »
I the points I have are:
Marshal L27
CCW#18-000-513
CCW/KEC 440RV
Are these the correct points for Snow7? I just want to make sure they are correct before I send them out.
S_Kyle wrote:I the points I have are:
Marshal L27
CCW#18-000-513
CCW/KEC 440RV
The CCW/KEC 440RV might possibly be.
