Hey guys,
Got my internet in the garage so have almost everything here I need.
Question, does anybody have any information on putting twin mikunis and CDI on my JDX4 340/5?
What I would hope to end up with is a quasi/295s for my X4. Probably need a donor engine from a 340 cyclone to get most of the CDI parts (also need a fan guard in decent condition for the engine...anyone?), and I am assuming that the mikuni specs of the 295s would be a good start to the carb set-up.
Any thoughts?
Robin
Twin mikunis and CDI on JDX4
1972 Ski-Doo Olympique 300
1972 Arctic Cat 340 Cheetah
1974 JDX4
1976 340 Cyclone
1977 Ski-Doo 340E Olympique
1978 Kawasaki 440 Intriguer
1978 Kawasaki 440 Invader
1980 Porsche 924
1985 Ski-Doo Formula Plus
1987 Polaris Indy Sport
2002 Lincoln LS V8
Thank God for big garages...and tolerant wives!.
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
Re: Twin mikunis and CDI on JDX4
Robin, good to see you're still around. lwb140 just did a custom JDX4 project with a 440/22 w/ dual mikunis and CDI, there's a post here some where.
awesome project !! you will need to make or find 295/s intake manifolds i used the liquifire dual carb set-up no reason those couldnt be made
- 2-1-11 047.JPG (178.91 KiB) Viewed 391 times
- jdx4 013.JPG (156.06 KiB) Viewed 391 times
- jdx4 012.JPG (158.02 KiB) Viewed 391 times
Cool sled!
I think the CDI is a pretty straight up deal, get a cyclone and bolt it on , but the carbs I am a little more concerned about getting right. I am not exactly sure what the difference is between my 340/5 and the 340rs engine internally (the specs look indentical) maybe bearing sizes etc, so do I go with the VM34's and the 340/s set-up or do I assume that the 340/5 engine/exhaust does not flow as well and go with the VM32's of the 295/s . ..does it really matter? To be quite honest, I understand that I would probably be better off just going with a single carb, but I look at it this way, would I have put a 2 barrel carb on my 1973 Mach 1 (RIP) if I was going to rebuild it from the ground up...ah no.
Any more thoughts?
Robin
Any more thoughts?
Robin
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
the porting on the rs motors is more aggressive but i think it will run fine with 2 34s on it if you have them the 340/s jetting would be a great place to start like i said before tho the intakes may be tough to find and you may just have to make them otherwise it should be a fairly strait foreward deal making the intakes could be done but matching up a flang on the jug end but just using some tubing on the carb end to use a spigot type mount like the sportfires ive seen it done this way on jr dragsters and go-karts with no problem this would eliminate the 2 bolt carb boots too which have been known to leak just my thoughts wade
