Swapping Mikuni Carbs on Spitfires?
So, can you pretty much swap out and Mikuni carb (butterfly or slide) on any of the Spitfire sleds? Also, can you space between Kohler and Kawasaki? Anything that needs to happen for them to work, or is it pretty much a plug and play kind of thing?
- 80spitfire
- Real Name: Brian Kottke
Re: Swapping Mikuni Carbs on Spitfires?
To swap the carbs you will need new choke and throttle cables. I believe that you also need all new carb boots.
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
- 80spitfire
Yeah good point I didn't think of that.
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
