80 Liquifire track & suspension in a 78 Cyclone
jd_decalguy
Post by jd_decalguy »
Does anyone know exactly what I need to do to install a 80 Liquifire Drivers, track & suspension in a 78 Cyclone??
Chris Dotzler
Palisade, MN
Re: 80 Liquifire track & suspension in a 78 Cyclone
Some wrenches aand a socket set.
IS that what you were asking?
Or can't you remember? :whistle:
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
I think you have to move the tunnel mounting holes.
JDXspec
Real Name: Dustin
Post by JDXspec »
The drivers and shaft are bolt in deal. It makes it more simple if you use the AC track (16x121) Then you can use 2 of the existing holes with the 80 LF susp. I am doing a AC track swap with an 80 LF susp In a 76 LF chassis. They fit pretty well. the 78 are a bit different with mounting holes but it will work.
Kenny,
Why do you want to use the shorter track? I smell something evil here...
A few of the guys are working on making clone 78 CC skids to use the 121" rubber Cat track. It seems to start with an 80 LF skid, but requires new rear axle brackets to use the larger 7 1/8" idler. Waters boy did something simular to his I-500 sled to go to a 121 on an 80 LF.
-Rainville
jd_decalguy
Joe, nothing going on, other than I'm to cheap to spend that much on Tuckers Cyclone & the fact that we have 4 80 Liquifire doner sleds that hopefully I can find a good track in.. I already found on of them having a bad track.. I was hoping that some one had already done so, So I would know IF I had to drill different holes or what?? & where to drill them..
Chris Dotzler
Palisade, MN
lwb140
Real Name: Wade bennett
Post by lwb140 »
kenny ive got a dator with this deal in it a 116 lf track and 80 skid i think it looks ok just wish it was all stock tho new holes were required i could get you the measurements [locations ] of the holes wade
mbsledhead
Post by mbsledhead »
I'd like the measurements as well, as I have the same situation. Instead I'd be putting the 80 track,skid and drive into a 76 liquifire.
Jeff
lwb140
Post by lwb140 »
guys ill see if i can get some pics and measurements tomarrow or sometime soon
