Pulling A Clutch Without Stripping It
What is the best way to pull a clutch without stripping it? I had a clutch on a 79 trailfire that stripped when my local sled shop tried to pull it. He tightened it up and it stripped. He has been doing this for years so I don't think he did anything wrong. I have a few sleds that I want to pull the clutches but am scared that they will strip. Some come off easy but others seem to be stuck tight.
- jdrob
- Real Name: Rob
Re: Pulling A Clutch Without Stripping It
Mike i like to use grease or tranny fluid and if that does not work. I use a propane torch and heat the sheave lightly and then use the puller on it !! I hope this helps ! Good luck!
Rob
Rob
Jdrob
I stripped mine out once and was using the grease method! I believe sometimes these things are just stuck. I have heard that if you just tighten the puller up(not stripping it out tight) and let it sit over night, some have woken up to it off the sled.
Keith
Keith
1984 Sportfire..Work in Progress!
i have had luck leaving them over night with tension on them, using heat as well and tapping the puller with a hammer loosens them up as well and you can tighten them up a little tighter after you tap a few times on it. Or the last resort cut it off
